Date/Time: Sun, 22 Dec 2024 07:48:05 +0000
Sierra data feed
View Count: 1852
[2015-04-23 21:05:05] |
TradingSignalsSoftware - Posts: 35 |
I need the following feeds -CME -NYSE -DAX -Gold Can you please advise whether the feed will be live/real time with sierra and what would be the cost in total for above and whether you can offer discount? I am none professional user. |
[2015-04-23 22:09:47] |
In regards to CME data, refer to this section to understand the cost: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME And refer to the Introduction section here for the cost of the Sierra Chart Exchange Data Feed and the other exchanges: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-24 08:40:49] |
AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2015-04-24 04:35:48 Notice: Sierra Chart usage time has ended. Disconnecting from the data feed. | 2015-04-24 04:35:48 * To purchase more usage time, select 'Help >> Add Usage Credit' and restart Sierra Chart | 2015-04-24 04:35:48 Socket (55) | Shutdown and closed. | 2015-04-24 04:35:48 IQFeed | Disconnected from Admin port. | 2015-04-24 04:35:48 IQFeed | Fully disconnected. | 2015-04-24 04:35:48 |
[2015-04-24 08:41:16] |
My trial should have been extended
[2015-04-24 09:04:00] |
You need to restart Sierra Chart.
[2015-04-24 09:21:02] |
Thank you, can you tell me which feed I need for the FTSE 100 feed as well please, I rather not open open a account with fxcm are there alternatives? |
[2015-04-24 18:43:42] |
You could use the Sierra Chart Real-time and Historical Forex/CFD Data Feed: http://www.sierrachart.com/index.php?page=doc/SCRealTimeFOREX.php The symbol is UK100. Or you could activate the LIFFE exchange when using the Sierra Chart Exchange Data Feed: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
