Date/Time: Sat, 19 Sep 2026 05:24:22 +0000
spreedsheet
View Count: 1122
[2015-04-23 21:02:24]
User251871 - Posts: 16
Hello
I am a new user and use your spreadsheet, I noticed that the data output in the sheet slower than the data of the graph
is it possible to increase the data output speed in the sheet?
[2015-04-23 21:58:35]
The spreadsheet is definitely updated at the same rate has the chart, but possibly you are experiencing a delay with the actual drawing of the sheet based upon the load of the CPU.
We will make sure that the update is not delayed.
[2015-04-24 10:14:07]
Please take a look at the attached.
I only outputed the price without studies , and did not write any formula in the spreadsheet.
imagedelay in update the price in the sheet.jpg / V - Attached On 2015-04-24 10:13:45 UTC - Size: 418.96 KB - 414 views
[2015-04-24 18:59:48]
You cannot make a comparison of a spreadsheet to an external program. If that is the basis of the delay, it is not valid.
Refer to help topic 4:
Http://www.sierrachart.com/index.php?page=doc/helpdetails4.html
