Date/Time: Fri, 22 Nov 2024 19:37:40 +0000
[User Discussion] - Always on Top
View Count: 2375
[2013-06-02 18:22:28] |
nicker1 - Posts: 10 |
I do not want Sierra Charts Always on Top. With the last month or so they became always on top.... no idea why. Under "Window" the 'always on top' is greyed out. How can I fix this? v. 982 as of today. problem persists Thanks a lot |
[2013-06-02 20:45:30] |
Are you referring to the Sierra Chart main window? If so, there is no functionality to make that always on top. If it is, there must be something on your system doing it.
[2013-06-02 21:03:36] |
Yes, the main SC window is always on top, as of the last 2-3 weeks. Thanks for the info. Hmmmm. Hopefully someone might have solved the same problem and can tell me where to look. Tyvm
[2013-06-03 02:52:27] |
M5amhan - Posts: 468 |
i was wondering myself if windows had this feature, and it doesnt look like they do. according to this link, it looks like something else like a video card may be enabling this. maybe try downloading the application in this link (given in the answer) and then turn off "always on top" that way. http://answers.microsoft.com/en-us/windows/forum/windows_7-desktop/how-do-i-keep-a-window-to-always-stay-on-top-in/4f9f6f87-0e52-49cc-9053-168e1405a107 hope this helps |
