Date/Time: Sun, 22 Dec 2024 08:02:54 +0000
Trade DOM - how to colour for Live or SIM mode
View Count: 1072
[2015-04-23 15:18:50] |
User13668 - Posts: 294 |
Okay I am stumped. See attached screen grab of a Trade DOM with attached Trade Window. You can see that in SIM mode I have the Trade Window coloured turquoise (and for Live it is orange). But how do I get those same colour profiles to show up on the Trade DOM itself inside the area circled in red? I know how to do it for a normal chart, but cannot for the life of me make it work on the Trade DOM. |
TradeDOMCapture.PNG / V - Attached On 2015-04-23 15:18:40 UTC - Size: 40.8 KB - 392 views |
[2015-04-23 22:02:56] |
We had a look into this, and it is not supported. There is only one color set, a foreground and background which sets that quantity text in the case of the trade DOM.
[2015-04-24 06:25:53] |
Understand. Seems like an unintentional omission as it would be very useful so you can use colors to draw your attention to whether you are in SIM or Live mode - just like you can on the main price chart. Maybe could be added at some point in the future ........ |
