Date/Time: Thu, 31 Oct 2024 10:13:07 +0000
Trade
View Count: 777
[2015-04-23 14:08:42] |
User25116 - Posts: 27 |
I tried putting a trade in and kept putting me in simulation mode even though I would disable it. I have a ten minute delay before candles show up I checked with iQfeed and they said their end is fine |
[2015-04-23 23:06:25] |
When using IQ Feed directly, you cannot submit orders. What Trading/broker do you use for trading? The 10 minute delay means you are receiving delayed data from IQ Feed. Contact IQ Feed about this. They definitely will be able to help you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
