Date/Time: Mon, 05 Oct 2026 02:37:31 +0000
Error opening the InternalOrderID.data file for writing. Error: Windows error code 5: Access is
View Count: 1718
| [2015-04-23 08:23:02] |
| User934555 - Posts: 5 |
yesterday was working great today, after restart the machine i got this mesage log Error opening the InternalOrderID.data file for writing. Error: Windows error code 5: Access is denied. | 2015-04-23 03:09:45 * Software version: 1241 | 2015-04-23 03:09:45 Uses Old Spreadsheets | 2015-04-23 03:09:45 Usage end date: 2015-05-20 | 2015-04-23 03:09:45 Enabled for: Advanced Features. | 2015-04-23 03:09:45 Enabled for: Advanced Features 2. | 2015-04-23 03:09:45 Enabled for: Sierra Chart Historical Data Service. | 2015-04-23 03:09:45 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-04-23 03:09:45 Active service: Rithmic Trading | 2015-04-23 03:09:45 Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-04-23 03:09:45 2015-04-23 03:09:45 Local computer clock time | 2015-04-23 03:09:45 2015-04-23 08:09:45 GMT time | 2015-04-23 03:09:45 2015-04-23 03:09:45 Time zone adjusted time | 2015-04-23 03:09:45 Time difference to server time: 4 seconds. | 2015-04-23 03:09:45 Program path: C:\sierra_tst\ | 2015-04-23 03:09:45 Data Files path: C:\sierra_tst\Data\ | 2015-04-23 03:09:45 OS Version Number: 6.2 | 2015-04-23 03:09:45 Locale Information: C | 2015-04-23 03:09:45 Checking for new symbol settings for rim | 2015-04-23 03:09:45 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-04-23 03:09:45 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-04-23 03:09:45 Requesting symbol settings for rim. Overwrite = on. | 2015-04-23 03:09:45 Symbol settings received. | 2015-04-23 03:09:46 Processed received symbol settings | 2015-04-23 03:09:46 Rithmic Trading | Port for executable: 49732 | 2015-04-23 03:09:50 Listening socket (1948), port 49732 | Closed. | 2015-04-23 03:09:50 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:09:50 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-04-23 03:09:51 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-04-23 03:09:51 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49732 | 2015-04-23 03:09:52 Socket (2) | Connected. | 2015-04-23 03:09:52 Rithmic Trading | Connected to server. | 2015-04-23 03:09:52 Rithmic Trading | Sending logon request message. | 2015-04-23 03:09:52 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:09:52 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:09:52 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:09:52 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:09:52 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:09:52 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:09:52 Rithmic Trading | Logon error from server | 2015-04-23 03:09:52 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:09:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:09:52 Socket (2) | Closed. No error. | 2015-04-23 03:09:52 Socket (2) | Shutdown and closed. | 2015-04-23 03:09:52 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:09:52 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:09:52 Rithmic Trading | Port for executable: 49735 | 2015-04-23 03:09:54 Listening socket (1952), port 49735 | Closed. | 2015-04-23 03:09:54 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:09:54 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49735 | 2015-04-23 03:09:56 Socket (3) | Connected. | 2015-04-23 03:09:56 Rithmic Trading | Connected to server. | 2015-04-23 03:09:56 Rithmic Trading | Sending logon request message. | 2015-04-23 03:09:56 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:09:56 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:09:56 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:09:56 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:09:56 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:09:56 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:09:56 Rithmic Trading | Logon error from server | 2015-04-23 03:09:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:09:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:09:56 Socket (3) | Closed. No error. | 2015-04-23 03:09:56 Socket (3) | Shutdown and closed. | 2015-04-23 03:09:56 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:09:56 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:09:56 Rithmic Trading | Port for executable: 49737 | 2015-04-23 03:09:59 Listening socket (1268), port 49737 | Closed. | 2015-04-23 03:09:59 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:09:59 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49737 | 2015-04-23 03:10:01 Socket (4) | Connected. | 2015-04-23 03:10:01 Rithmic Trading | Connected to server. | 2015-04-23 03:10:01 Rithmic Trading | Sending logon request message. | 2015-04-23 03:10:01 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:10:01 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:10:01 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:10:01 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:10:01 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:10:01 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:10:01 Rithmic Trading | Logon error from server | 2015-04-23 03:10:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:10:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:10:01 Socket (4) | Closed. No error. | 2015-04-23 03:10:01 Socket (4) | Shutdown and closed. | 2015-04-23 03:10:01 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:10:01 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:10:01 Rithmic Trading | Port for executable: 49745 | 2015-04-23 03:10:03 Listening socket (1936), port 49745 | Closed. | 2015-04-23 03:10:03 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:10:03 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49745 | 2015-04-23 03:10:05 Socket (5) | Connected. | 2015-04-23 03:10:05 Rithmic Trading | Connected to server. | 2015-04-23 03:10:05 Rithmic Trading | Sending logon request message. | 2015-04-23 03:10:05 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:10:05 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:10:05 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:10:05 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:10:05 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:10:05 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:10:05 Rithmic Trading | Logon error from server | 2015-04-23 03:10:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:10:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:10:05 Socket (5) | Closed. No error. | 2015-04-23 03:10:05 Socket (5) | Shutdown and closed. | 2015-04-23 03:10:05 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:10:05 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:10:05 Rithmic Trading | Port for executable: 49747 | 2015-04-23 03:10:07 Listening socket (1948), port 49747 | Closed. | 2015-04-23 03:10:07 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:10:07 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49747 | 2015-04-23 03:10:09 Socket (6) | Connected. | 2015-04-23 03:10:09 Rithmic Trading | Connected to server. | 2015-04-23 03:10:09 Rithmic Trading | Sending logon request message. | 2015-04-23 03:10:09 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:10:09 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:10:09 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:10:09 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:10:09 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:10:09 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:10:09 Rithmic Trading | Logon error from server | 2015-04-23 03:10:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:10:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:10:09 Socket (6) | Closed. No error. | 2015-04-23 03:10:09 Socket (6) | Shutdown and closed. | 2015-04-23 03:10:09 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:10:09 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:10:09 Rithmic Trading | Port for executable: 49752 | 2015-04-23 03:10:11 Listening socket (2220), port 49752 | Closed. | 2015-04-23 03:10:11 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:10:11 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49752 | 2015-04-23 03:10:13 Socket (7) | Connected. | 2015-04-23 03:10:13 Rithmic Trading | Connected to server. | 2015-04-23 03:10:13 Rithmic Trading | Sending logon request message. | 2015-04-23 03:10:13 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:10:13 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:10:13 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:10:13 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:10:13 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:10:13 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:10:13 Rithmic Trading | Logon error from server | 2015-04-23 03:10:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:10:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:10:13 Socket (7) | Closed. No error. | 2015-04-23 03:10:13 Socket (7) | Shutdown and closed. | 2015-04-23 03:10:13 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:10:13 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:10:13 Rithmic Trading | Port for executable: 49758 | 2015-04-23 03:10:15 Listening socket (2220), port 49758 | Closed. | 2015-04-23 03:10:15 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:10:15 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49758 | 2015-04-23 03:10:17 Socket (8) | Connected. | 2015-04-23 03:10:17 Rithmic Trading | Connected to server. | 2015-04-23 03:10:17 Rithmic Trading | Sending logon request message. | 2015-04-23 03:10:17 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:10:17 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:10:17 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:10:17 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:10:17 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:10:17 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:10:17 Rithmic Trading | Logon error from server | 2015-04-23 03:10:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:10:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:10:17 Socket (8) | Closed. No error. | 2015-04-23 03:10:17 Socket (8) | Shutdown and closed. | 2015-04-23 03:10:17 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:10:17 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:10:17 Rithmic Trading | Port for executable: 49761 | 2015-04-23 03:10:19 Listening socket (2228), port 49761 | Closed. | 2015-04-23 03:10:19 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:10:19 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49761 | 2015-04-23 03:10:21 Socket (9) | Connected. | 2015-04-23 03:10:21 Rithmic Trading | Connected to server. | 2015-04-23 03:10:21 Rithmic Trading | Sending logon request message. | 2015-04-23 03:10:21 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:10:21 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:10:21 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:10:21 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:10:21 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:10:21 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:10:21 Rithmic Trading | Logon error from server | 2015-04-23 03:10:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:10:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:10:21 Socket (9) | Closed. No error. | 2015-04-23 03:10:21 Socket (9) | Shutdown and closed. | 2015-04-23 03:10:21 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:10:21 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:10:21 Rithmic Trading | Port for executable: 49763 | 2015-04-23 03:10:23 Listening socket (1960), port 49763 | Closed. | 2015-04-23 03:10:23 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:10:23 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49763 | 2015-04-23 03:10:25 Socket (10) | Connected. | 2015-04-23 03:10:25 Rithmic Trading | Connected to server. | 2015-04-23 03:10:25 Rithmic Trading | Sending logon request message. | 2015-04-23 03:10:25 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:10:25 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:10:25 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:10:25 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:10:25 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:10:25 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:10:25 Rithmic Trading | Logon error from server | 2015-04-23 03:10:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:10:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:10:25 Socket (10) | Closed. No error. | 2015-04-23 03:10:25 Socket (10) | Shutdown and closed. | 2015-04-23 03:10:25 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:10:25 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:10:25 Rithmic Trading | Port for executable: 49765 | 2015-04-23 03:10:27 Listening socket (2148), port 49765 | Closed. | 2015-04-23 03:10:27 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:10:27 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49765 | 2015-04-23 03:10:29 Socket (11) | Connected. | 2015-04-23 03:10:29 Rithmic Trading | Connected to server. | 2015-04-23 03:10:29 Rithmic Trading | Sending logon request message. | 2015-04-23 03:10:29 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:10:29 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:10:29 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:10:29 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:10:29 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:10:29 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:10:29 Rithmic Trading | Logon error from server | 2015-04-23 03:10:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:10:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:10:29 Socket (11) | Closed. No error. | 2015-04-23 03:10:29 Socket (11) | Shutdown and closed. | 2015-04-23 03:10:29 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:10:29 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:10:29 Rithmic Trading | Port for executable: 49769 | 2015-04-23 03:10:31 Listening socket (1956), port 49769 | Closed. | 2015-04-23 03:10:31 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:10:31 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49769 | 2015-04-23 03:10:33 Socket (12) | Connected. | 2015-04-23 03:10:33 Rithmic Trading | Connected to server. | 2015-04-23 03:10:33 Rithmic Trading | Sending logon request message. | 2015-04-23 03:10:33 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:10:33 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:10:33 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:10:33 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:10:33 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:10:33 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:10:33 Rithmic Trading | Logon error from server | 2015-04-23 03:10:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:10:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:10:33 Socket (12) | Closed. No error. | 2015-04-23 03:10:33 Socket (12) | Shutdown and closed. | 2015-04-23 03:10:33 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:10:33 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:10:33 Rithmic Trading | Port for executable: 49771 | 2015-04-23 03:10:35 Listening socket (2224), port 49771 | Closed. | 2015-04-23 03:10:35 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:10:35 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49771 | 2015-04-23 03:10:38 Socket (13) | Connected. | 2015-04-23 03:10:38 Rithmic Trading | Connected to server. | 2015-04-23 03:10:38 Rithmic Trading | Sending logon request message. | 2015-04-23 03:10:38 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:10:38 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:10:38 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:10:38 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:10:38 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:10:38 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:10:38 Rithmic Trading | Logon error from server | 2015-04-23 03:10:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:10:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:10:38 Socket (13) | Closed. No error. | 2015-04-23 03:10:38 Socket (13) | Shutdown and closed. | 2015-04-23 03:10:38 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:10:38 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:10:38 Rithmic Trading | Port for executable: 49776 | 2015-04-23 03:10:40 Listening socket (2240), port 49776 | Closed. | 2015-04-23 03:10:40 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:10:40 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49776 | 2015-04-23 03:10:42 Socket (14) | Connected. | 2015-04-23 03:10:42 Rithmic Trading | Connected to server. | 2015-04-23 03:10:42 Rithmic Trading | Sending logon request message. | 2015-04-23 03:10:42 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:10:42 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:10:42 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:10:42 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:10:42 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:10:42 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:10:42 Rithmic Trading | Logon error from server | 2015-04-23 03:10:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:10:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:10:42 Socket (14) | Closed. No error. | 2015-04-23 03:10:42 Socket (14) | Shutdown and closed. | 2015-04-23 03:10:42 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:10:42 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:10:42 Rithmic Trading | Port for executable: 49778 | 2015-04-23 03:10:44 Listening socket (2228), port 49778 | Closed. | 2015-04-23 03:10:44 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:10:44 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49778 | 2015-04-23 03:10:46 Socket (15) | Connected. | 2015-04-23 03:10:46 Rithmic Trading | Connected to server. | 2015-04-23 03:10:46 Rithmic Trading | Sending logon request message. | 2015-04-23 03:10:46 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:10:46 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:10:46 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:10:46 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:10:46 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:10:46 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:10:46 Rithmic Trading | Logon error from server | 2015-04-23 03:10:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:10:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:10:46 Socket (15) | Closed. No error. | 2015-04-23 03:10:46 Socket (15) | Shutdown and closed. | 2015-04-23 03:10:46 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:10:46 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:10:46 Rithmic Trading | Port for executable: 49780 | 2015-04-23 03:10:48 Listening socket (2256), port 49780 | Closed. | 2015-04-23 03:10:48 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:10:48 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49780 | 2015-04-23 03:10:50 Socket (16) | Connected. | 2015-04-23 03:10:50 Rithmic Trading | Connected to server. | 2015-04-23 03:10:50 Rithmic Trading | Sending logon request message. | 2015-04-23 03:10:50 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:10:50 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:10:50 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:10:50 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:10:50 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:10:50 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:10:50 Rithmic Trading | Logon error from server | 2015-04-23 03:10:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:10:50 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:10:50 Socket (16) | Closed. No error. | 2015-04-23 03:10:50 Socket (16) | Shutdown and closed. | 2015-04-23 03:10:50 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:10:50 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:10:50 Rithmic Trading | Port for executable: 49782 | 2015-04-23 03:10:52 Listening socket (2252), port 49782 | Closed. | 2015-04-23 03:10:52 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:10:52 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49782 | 2015-04-23 03:10:54 Socket (17) | Connected. | 2015-04-23 03:10:54 Rithmic Trading | Connected to server. | 2015-04-23 03:10:54 Rithmic Trading | Sending logon request message. | 2015-04-23 03:10:54 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:10:54 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:10:54 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:10:54 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:10:54 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:10:54 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:10:54 Rithmic Trading | Logon error from server | 2015-04-23 03:10:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:10:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:10:54 Socket (17) | Closed. No error. | 2015-04-23 03:10:54 Socket (17) | Shutdown and closed. | 2015-04-23 03:10:54 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:10:54 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:10:54 Rithmic Trading | Port for executable: 49785 | 2015-04-23 03:10:56 Listening socket (2252), port 49785 | Closed. | 2015-04-23 03:10:56 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:10:56 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49785 | 2015-04-23 03:10:58 Socket (18) | Connected. | 2015-04-23 03:10:58 Rithmic Trading | Connected to server. | 2015-04-23 03:10:58 Rithmic Trading | Sending logon request message. | 2015-04-23 03:10:58 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:10:58 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:10:58 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:10:58 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:10:58 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:10:58 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:10:58 Rithmic Trading | Logon error from server | 2015-04-23 03:10:58 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:10:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:10:58 Socket (18) | Closed. No error. | 2015-04-23 03:10:58 Socket (18) | Shutdown and closed. | 2015-04-23 03:10:58 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:10:58 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:10:58 Rithmic Trading | Port for executable: 49787 | 2015-04-23 03:11:00 Listening socket (1948), port 49787 | Closed. | 2015-04-23 03:11:00 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:11:00 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49787 | 2015-04-23 03:11:02 Socket (19) | Connected. | 2015-04-23 03:11:02 Rithmic Trading | Connected to server. | 2015-04-23 03:11:02 Rithmic Trading | Sending logon request message. | 2015-04-23 03:11:02 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:11:02 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:11:02 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:11:02 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:11:02 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:11:02 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:11:02 Rithmic Trading | Logon error from server | 2015-04-23 03:11:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:11:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:11:02 Socket (19) | Closed. No error. | 2015-04-23 03:11:02 Socket (19) | Shutdown and closed. | 2015-04-23 03:11:02 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:11:02 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:11:02 Rithmic Trading | Port for executable: 49789 | 2015-04-23 03:11:04 Listening socket (1928), port 49789 | Closed. | 2015-04-23 03:11:04 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:11:04 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49789 | 2015-04-23 03:11:06 Socket (20) | Connected. | 2015-04-23 03:11:06 Rithmic Trading | Connected to server. | 2015-04-23 03:11:06 Rithmic Trading | Sending logon request message. | 2015-04-23 03:11:06 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:11:06 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:11:06 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:11:06 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:11:06 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:11:06 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:11:06 Rithmic Trading | Logon error from server | 2015-04-23 03:11:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:11:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:11:06 Socket (20) | Closed. No error. | 2015-04-23 03:11:06 Socket (20) | Shutdown and closed. | 2015-04-23 03:11:06 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:11:06 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:11:06 Rithmic Trading | Port for executable: 49791 | 2015-04-23 03:11:08 Listening socket (2120), port 49791 | Closed. | 2015-04-23 03:11:08 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:11:08 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49791 | 2015-04-23 03:11:10 Socket (21) | Connected. | 2015-04-23 03:11:10 Rithmic Trading | Connected to server. | 2015-04-23 03:11:10 Rithmic Trading | Sending logon request message. | 2015-04-23 03:11:10 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:11:10 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:11:10 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:11:10 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:11:10 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:11:10 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:11:10 Rithmic Trading | Logon error from server | 2015-04-23 03:11:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:11:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:11:10 Socket (21) | Closed. No error. | 2015-04-23 03:11:10 Socket (21) | Shutdown and closed. | 2015-04-23 03:11:10 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:11:10 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:11:10 Rithmic Trading | Port for executable: 49796 | 2015-04-23 03:11:12 Listening socket (2120), port 49796 | Closed. | 2015-04-23 03:11:12 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:11:12 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49796 | 2015-04-23 03:11:14 Socket (22) | Connected. | 2015-04-23 03:11:14 Rithmic Trading | Connected to server. | 2015-04-23 03:11:14 Rithmic Trading | Sending logon request message. | 2015-04-23 03:11:14 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:11:14 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:11:14 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:11:14 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:11:14 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:11:14 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:11:14 Rithmic Trading | Logon error from server | 2015-04-23 03:11:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:11:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:11:14 Socket (22) | Closed. No error. | 2015-04-23 03:11:14 Socket (22) | Shutdown and closed. | 2015-04-23 03:11:14 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:11:14 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:11:14 Rithmic Trading | Port for executable: 49798 | 2015-04-23 03:11:16 Listening socket (2248), port 49798 | Closed. | 2015-04-23 03:11:16 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:11:16 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49798 | 2015-04-23 03:11:18 Socket (23) | Connected. | 2015-04-23 03:11:18 Rithmic Trading | Connected to server. | 2015-04-23 03:11:18 Rithmic Trading | Sending logon request message. | 2015-04-23 03:11:18 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:11:18 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:11:18 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:11:18 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:11:18 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:11:18 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:11:18 Rithmic Trading | Logon error from server | 2015-04-23 03:11:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:11:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:11:18 Socket (23) | Closed. No error. | 2015-04-23 03:11:18 Socket (23) | Shutdown and closed. | 2015-04-23 03:11:18 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:11:18 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:11:18 Rithmic Trading | Port for executable: 49800 | 2015-04-23 03:11:20 Listening socket (2252), port 49800 | Closed. | 2015-04-23 03:11:20 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:11:20 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49800 | 2015-04-23 03:11:22 Socket (24) | Connected. | 2015-04-23 03:11:22 Rithmic Trading | Connected to server. | 2015-04-23 03:11:22 Rithmic Trading | Sending logon request message. | 2015-04-23 03:11:22 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:11:22 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:11:22 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:11:22 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:11:22 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:11:22 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:11:22 Rithmic Trading | Logon error from server | 2015-04-23 03:11:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:11:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:11:23 Socket (24) | Closed. No error. | 2015-04-23 03:11:23 Socket (24) | Shutdown and closed. | 2015-04-23 03:11:23 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:11:23 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:11:23 Rithmic Trading | Port for executable: 49802 | 2015-04-23 03:11:25 Listening socket (2240), port 49802 | Closed. | 2015-04-23 03:11:25 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:11:25 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49802 | 2015-04-23 03:11:27 Socket (25) | Connected. | 2015-04-23 03:11:27 Rithmic Trading | Connected to server. | 2015-04-23 03:11:27 Rithmic Trading | Sending logon request message. | 2015-04-23 03:11:27 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:11:27 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:11:27 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:11:27 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:11:27 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:11:27 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:11:27 Rithmic Trading | Logon error from server | 2015-04-23 03:11:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:11:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:11:27 Socket (25) | Closed. No error. | 2015-04-23 03:11:27 Socket (25) | Shutdown and closed. | 2015-04-23 03:11:27 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:11:27 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:11:27 Rithmic Trading | Port for executable: 49804 | 2015-04-23 03:11:29 Listening socket (2232), port 49804 | Closed. | 2015-04-23 03:11:29 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:11:29 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49804 | 2015-04-23 03:11:31 Socket (26) | Connected. | 2015-04-23 03:11:31 Rithmic Trading | Connected to server. | 2015-04-23 03:11:31 Rithmic Trading | Sending logon request message. | 2015-04-23 03:11:31 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:11:31 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:11:31 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:11:31 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:11:31 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:11:31 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:11:31 Rithmic Trading | Logon error from server | 2015-04-23 03:11:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:11:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:11:31 Socket (26) | Closed. No error. | 2015-04-23 03:11:31 Socket (26) | Shutdown and closed. | 2015-04-23 03:11:31 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:11:31 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:11:31 Rithmic Trading | Port for executable: 49806 | 2015-04-23 03:11:33 Listening socket (2008), port 49806 | Closed. | 2015-04-23 03:11:33 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:11:33 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49806 | 2015-04-23 03:11:35 Socket (27) | Connected. | 2015-04-23 03:11:35 Rithmic Trading | Connected to server. | 2015-04-23 03:11:35 Rithmic Trading | Sending logon request message. | 2015-04-23 03:11:35 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:11:35 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:11:35 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:11:35 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:11:35 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:11:35 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:11:35 Rithmic Trading | Logon error from server | 2015-04-23 03:11:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:11:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:11:35 Socket (27) | Closed. No error. | 2015-04-23 03:11:35 Socket (27) | Shutdown and closed. | 2015-04-23 03:11:35 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:11:35 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:11:35 Rithmic Trading | Port for executable: 49808 | 2015-04-23 03:11:37 Listening socket (1016), port 49808 | Closed. | 2015-04-23 03:11:37 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:11:37 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49808 | 2015-04-23 03:11:39 Socket (28) | Connected. | 2015-04-23 03:11:39 Rithmic Trading | Connected to server. | 2015-04-23 03:11:39 Rithmic Trading | Sending logon request message. | 2015-04-23 03:11:39 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:11:39 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:11:39 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:11:39 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:11:39 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:11:39 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:11:39 Rithmic Trading | Logon error from server | 2015-04-23 03:11:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:11:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:11:39 Socket (28) | Closed. No error. | 2015-04-23 03:11:39 Socket (28) | Shutdown and closed. | 2015-04-23 03:11:39 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:11:39 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:11:39 Rithmic Trading | Port for executable: 49813 | 2015-04-23 03:11:41 Listening socket (2248), port 49813 | Closed. | 2015-04-23 03:11:41 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:11:41 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49813 | 2015-04-23 03:11:43 Socket (29) | Connected. | 2015-04-23 03:11:43 Rithmic Trading | Connected to server. | 2015-04-23 03:11:43 Rithmic Trading | Sending logon request message. | 2015-04-23 03:11:43 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:11:43 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:11:43 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:11:43 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:11:43 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:11:43 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:11:43 Rithmic Trading | Logon error from server | 2015-04-23 03:11:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:11:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:11:43 Socket (29) | Closed. No error. | 2015-04-23 03:11:43 Socket (29) | Shutdown and closed. | 2015-04-23 03:11:43 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:11:43 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:11:43 Rithmic Trading | Port for executable: 49818 | 2015-04-23 03:11:45 Listening socket (1948), port 49818 | Closed. | 2015-04-23 03:11:45 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:11:45 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49818 | 2015-04-23 03:11:47 Socket (30) | Connected. | 2015-04-23 03:11:47 Rithmic Trading | Connected to server. | 2015-04-23 03:11:47 Rithmic Trading | Sending logon request message. | 2015-04-23 03:11:47 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:11:47 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:11:47 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:11:47 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:11:47 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:11:47 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:11:47 Rithmic Trading | Logon error from server | 2015-04-23 03:11:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:11:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:11:47 Socket (30) | Closed. No error. | 2015-04-23 03:11:47 Socket (30) | Shutdown and closed. | 2015-04-23 03:11:47 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:11:47 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:11:47 Rithmic Trading | Port for executable: 49820 | 2015-04-23 03:11:49 Listening socket (2232), port 49820 | Closed. | 2015-04-23 03:11:49 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:11:49 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49820 | 2015-04-23 03:11:51 Socket (31) | Connected. | 2015-04-23 03:11:51 Rithmic Trading | Connected to server. | 2015-04-23 03:11:51 Rithmic Trading | Sending logon request message. | 2015-04-23 03:11:51 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:11:51 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:11:51 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:11:51 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:11:51 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:11:51 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:11:51 Rithmic Trading | Logon error from server | 2015-04-23 03:11:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:11:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:11:51 Socket (31) | Closed. No error. | 2015-04-23 03:11:51 Socket (31) | Shutdown and closed. | 2015-04-23 03:11:51 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:11:51 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:11:51 Rithmic Trading | Port for executable: 49868 | 2015-04-23 03:14:51 Listening socket (1948), port 49868 | Closed. | 2015-04-23 03:14:51 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:14:51 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49868 | 2015-04-23 03:14:53 Socket (32) | Connected. | 2015-04-23 03:14:53 Rithmic Trading | Connected to server. | 2015-04-23 03:14:53 Rithmic Trading | Sending logon request message. | 2015-04-23 03:14:53 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:14:53 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:14:53 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:14:53 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:14:53 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:14:53 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:14:53 Rithmic Trading | Logon error from server | 2015-04-23 03:14:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:14:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:14:53 Socket (32) | Closed. No error. | 2015-04-23 03:14:53 Socket (32) | Shutdown and closed. | 2015-04-23 03:14:53 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:14:53 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:14:53 Rithmic Trading | Port for executable: 49901 | 2015-04-23 03:17:53 Listening socket (2296), port 49901 | Closed. | 2015-04-23 03:17:53 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:17:53 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49901 | 2015-04-23 03:17:55 Socket (33) | Connected. | 2015-04-23 03:17:55 Rithmic Trading | Connected to server. | 2015-04-23 03:17:55 Rithmic Trading | Sending logon request message. | 2015-04-23 03:17:55 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:17:55 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:17:55 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:17:55 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:17:55 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:17:55 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:17:55 Rithmic Trading | Logon error from server | 2015-04-23 03:17:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:17:55 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:17:55 Socket (33) | Closed. No error. | 2015-04-23 03:17:55 Socket (33) | Shutdown and closed. | 2015-04-23 03:17:55 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:17:55 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:17:55 Rithmic Trading | Port for executable: 49936 | 2015-04-23 03:20:55 Listening socket (2248), port 49936 | Closed. | 2015-04-23 03:20:55 Rithmic Trading | Starting server: C:\sierra_tst\Rim\DTCBridge.exe | 2015-04-23 03:20:55 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49936 | 2015-04-23 03:20:57 Socket (34) | Connected. | 2015-04-23 03:20:57 Rithmic Trading | Connected to server. | 2015-04-23 03:20:57 Rithmic Trading | Sending logon request message. | 2015-04-23 03:20:57 Rithmic Trading | Starting the connection process to data and trading service. | 2015-04-23 03:20:57 Rithmic Trading | Logging is enabled. Log file: C:\sierra_tst\Rim\Rithmic.log | 2015-04-23 03:20:57 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2015-04-23 03:20:57 Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:20:57 Rithmic Trading | Server Name: DTC Bridge. | 2015-04-23 03:20:57 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-04-23 03:20:57 Rithmic Trading | Logon error from server | 2015-04-23 03:20:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-04-23 03:20:57 To prevent further connection attempts, select 'File >> Disconnect'. | 2015-04-23 03:20:57 Socket (34) | Closed. No error. | 2015-04-23 03:20:57 Socket (34) | Shutdown and closed. | 2015-04-23 03:20:57 Rithmic Trading | Disconnected from the server. | 2015-04-23 03:20:57 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-04-23 03:20:57 |
| [2015-04-23 09:09:28] |
For help with this error message: Error opening the InternalOrderID.data file for writing. Error: Windows error code 5: Access is denied. Refer to this help topic: Error Messages When Opening Files For help with this message: Rithmic Trading | Error creating the main object. Error message: os error | 2015-04-23 03:17:55 Refer to step 17 here: Rithmic Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-23 09:31:16] |
executing sc run as administrator solve the problem
