Date/Time: Sun, 22 Dec 2024 08:41:29 +0000
VbP Drawing Tool Problem - Not Showing !
View Count: 821
[2015-04-23 07:01:39] |
Trader Ra - Posts: 87 |
hi. this only started happening after I upgraded to 1248, also happening on 1249. When I try to use the VbP drawing tool and select any region, the profile does not appear (its hidden). I then have to go into the studies window, open the settings for the profile and click OK. Then it appears on the chart. Tried this on a fresh new chartbook with a new chart with no other studies. other chart drawings appear as normal. Any idea why this is happening?
[2015-04-23 08:56:55] |
We see this problem and we will take care of it today.
[2015-04-26 07:52:44] |
hey this problem still exits in ver 1250 if im not mistaken.
[2015-04-26 09:28:16] |
We apologize. We will check on this again.
