Date/Time: Thu, 31 Oct 2024 10:13:00 +0000
Why I can't see some symbols at my SierraChart ?
View Count: 1879
[2015-04-23 01:26:35] |
benyeh1225 - Posts: 28 |
Hi Sir, I used CQG as my data feed. I cannot see symbol name "YG" (E-mini Euro Currency future at CME exchange) from my SierraChart. Please refer to the attached figure for the available symbols I saw from CQG FIX Trading system. Could you help to resolve it? Thank You. CHI CHIN YEH |
available symbols in CQG FIX trading.png / V - Attached On 2015-04-23 01:25:40 UTC - Size: 59.6 KB - 429 views |
[2015-04-23 05:33:40] |
Look in this list of symbols and tell us specifically which one you need: http://www.cqg.com/Docs/Symbols.pdf It does not seem as though YG is what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-23 06:07:39] |
Hi Sir, I saw the smbol "YG" at the following exchange: NYSE Liffe US: YG Mini Gold Futures Please help to add it into the symbol list of my SierraChart(with CQG FIX Trading feed) Thank you CHI CHIN YEH |
[2015-04-23 07:01:44] |
This symbol has now been added. Restart Sierra Chart and wait about 10 seconds and you will then see it in File >> Find Symbol.
[2015-04-23 07:39:42] |
Hi Sir, OK, now I can see it. Thanks a lot. CHI CHIN YEH |
