Date/Time: Thu, 31 Oct 2024 10:13:04 +0000
VX futures Live Data
View Count: 1340
[2015-04-22 22:25:53] |
Ez - Posts: 51 |
Hi, I added the CBOE data pkg earlier today. Trying to get the VX futures. But I sill am not getting live data or the [M] indicator showing Sierra override. I'm using NTbroker/CQG and I am unclear if the CBOE must be enabled through CQG as well in order to get this live Sierra DATA or not. (I *am getting VIX & SPX through Sierra feed) Also trying to determine what symbols are included in the CBOE pkg if someone could point me to a reference list. THX |
vix_data_feed.PNG / V - Attached On 2015-04-22 22:23:33 UTC - Size: 8.88 KB - 367 views |
[2015-04-23 04:14:46] |
i960 - Posts: 360 |
It's not CBOE you need, it's CFE Futures. 16$/month. http://cfe.cboe.com/ |
[2015-04-23 05:26:24] |
You do need to use CFE futures instead: https://www.sierrachart.com/usercp.php?page=SC_RealTime_DataFeed_SetExchanges And also for the available markets, refer to: http://cfe.cboe.com/ Since you are using CQG, if you do not see the equivalent symbol listed in File >> Find Symbol, let us know which ones you want and we will add to those. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-23 09:44:14] |
Ez - Posts: 51 |
Ah, Thank you.
