Date/Time: Fri, 22 Nov 2024 20:05:16 +0000
Numbers bars V2 background coloring question
View Count: 1624
[2013-06-02 15:40:01] |
PTG - Posts: 57 |
I'd like to have a background color option according to an absolute compare value for each of the 8 colors with the Ask/Bid Vol Difference for that price level, so e.g. 0-25% color for a delta < 50, 26-50% for delta from 50 to 200, 51-75% for delta from 200 to 500, 76-100% for delta > 500 in case these values are set to 50, 200, 500 resp. Question: 1. is this currently possible ? (I suspect not) 2. if not, would that be something you would implement ? |
[2013-06-02 21:03:40] |
PTG - Posts: 57 |
Got it. Answer: 1. yes. Brilliant. Can do this using the column 1/2/3 compare threshold using commas to separate them. Or: RTFM. It's in there. http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#InputSettings : "For example, if you specify 100, 500, 1000 and have set the Numbers Bars to Volume based coloring, the Volume at the price level is compared to the thresholds and then mapped to the correct quartile color." Thanks for providing great software at reasonable prices. It's a true pleasure to use compared to other packages. |
