Date/Time: Thu, 02 Jul 2026 19:00:32 +0000
Alert manager
View Count: 1124
| [2015-04-22 16:12:04] |
| User937837 - Posts: 6 |
Sierra's alert manager is not populating with data. Am using Windows 8.1.
| [2015-04-22 16:52:47] |
What type of an alert have you configured which you are expecting to see in Window >> Show/Hide Alert Manager >> Alerts Log? Is is a Simple Alert on a study? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-22 19:15:09] |
yes
| [2015-04-22 19:27:56] |
This means the simple alert is not evaluating to true. Change the formula to TRUE. This will always evaluate to true and at least give you a signal right away so you can test the Alerts Log. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-22 23:51:00] |
using true was recognized by alert manager but formula while recognized is not affecting chart The formula is =C>ID6.SG1 Date Time Of Last Edit: 2015-04-23 16:39:03
| [2015-04-23 02:33:42] |
What is the formula you are using?
| [2015-04-23 16:56:51] |
formula should be =C>ID5.SG1
| [2015-04-24 04:58:06] |
Just looking at the formula itself we see no problem with it. We recommend setting up a simple formula on a Moving Average study comparing the moving average to the closing price of a bar and see how that works. You may also need to set the Value Format properly: http://www.sierrachart.com/index.php?page=doc/doc_AlertCondAndScan.html#ValueFormat Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-24 16:53:12] |
Value Format change worked. Thanks for your patience. Ted |
