Date/Time: Sun, 22 Dec 2024 08:37:10 +0000
Where to specify SMS alert number?
View Count: 1592
[2015-04-22 15:31:26] |
VPhantom - Posts: 18 |
Hello, Looking for a way to step out of the office while stalking setups, I found and read the handful of threads regarding SMS alerts, I added a deposit for additional services and finally in the SMS control panel I enabled the concept. However, where do I specify my mobile number? Do I need to edit my account's "main/skype" number or is there another entry field I keep missing? :) |
[2015-04-22 16:15:42] |
Sierra Chart - Max - Posts: 5756 |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#AlertSoundSettings You will need to enter your number for the Alert that you want to setup under Global Settings >> General Settings >> Alerts >> SMS Number. Sierra Chart Support |
[2015-04-22 16:18:25] |
Ahh, in the software itself! Thank you. :)
