Date/Time: Mon, 21 Sep 2026 03:59:38 +0000
[User Discussion] - Using Study price overlay in ACSIL
View Count: 1398
[2015-04-22 13:54:52]
User36750 - Posts: 14
I am trying to program a study price overlay in a custom DLL instead of referencing to the data form a study price overlay you have to add to the chart yourself. There you can adjust in the settings "fill blanks with last value" so that you get a stair kind of graph when you use data from another timeframe. Is there an example how i can put this in a study price overlay in my custom DLL? As you can see in the screenshot the difference between the study price overlay used from the library and the custom one.Only when i relaod the custom indicator it will look like a stair.
second question i have is do you have an example how i can program (in ACSIL) for example when i have 3 conditions and 2 out of 3 has to be true?
imageKnipsel3.PNG / V - Attached On 2015-04-22 13:51:47 UTC - Size: 53.23 KB - 602 views
