Date/Time: Tue, 29 Sep 2026 02:38:17 +0000
CFDs / Watch List
View Count: 1239
[2015-04-21 16:27:55]
User56694 - Posts: 6
My broker is IB.
Can I add stock CFDs to the watch list. I tried, but it didn“t work.
If I could add CFDs to the watch list, it would be very helpful.
It would be fine if you could make it possible in a later version of sierra chart.
[2015-04-21 18:48:23]
There is no reason why this is not possible. You just add the symbol to the list.
What exactly is the problem you are having?
[2015-04-21 19:17:20]
I add for example SPY-CFD-SMART-USD-BAAVG to the Watch List then you can see, written in Watch List Label:SPY-CFD-SMART-USD-BAAVG
When I click on Label:SPY-CFD-SMART-USD-BAAVG the chart doesn`t appear. I think that SC can`t`t find the symbol and therefore nothing happens.
[2015-04-22 04:45:56]
Refer to the symbol format here:
Interactive Brokers Symbols: CFD Format
Remove the -BAAVG suffix.
Not sure how you added this symbol to the watchlist but it looks like you have added this as a Label. It should not be added that way. Add it just like a normal symbol.
[2015-04-22 11:27:56]
I follwed your suggestion.
I removed the -BAAVG suffix.
I pushed the add button and then I typed SPY-CFD-SMART-USD, nothing happend. The only thing I can see is the information "Downloading Historical Data. Bars may not appear until done", but in the end nothing happens.
imageMassegeLog.JPG / V - Attached On 2015-04-22 11:27:35 UTC - Size: 182.64 KB - 524 views
[2015-04-22 18:30:17]
We think the problem is this:
It is important that when using this symbol format, that there are no other symbols being used within Sierra Chart at the same time for the same CFD symbol with the -BAAVG suffix. Otherwise, you will not receive market data for the symbol.
When using this symbol: SPY-CFD-SMART-USD make sure the -BAAVG is not being used and reconnect to the data feed.
[2015-04-23 14:27:35]
I am using the symbol SPY-CFD-SMART-USD as you told me and it doesn`t work. I followed your instruction. I opened only one chartbook with one chart and not the same or any other symbol with the -BAAVG suffix was used.
[2015-04-23 17:24:59]
Update Sierra Chart to the current release with Help >> Download Current Version.
Restart Sierra Chart and try opening a chart for that symbol again.
