Date/Time: Sun, 27 Sep 2026 05:34:03 +0000
downloading chart book files from sierra web page
View Count: 3060
| [2015-04-21 08:02:04] |
| Tomas21 - Posts: 23 |
I'm having great difficulty downloading chart book files from sierra web page, I can only seem to save as html which I can't seem to open with file .. open chart book . thanks
| [2015-04-22 19:33:43] |
Provide a link to the webpage where there is a Chartbook that can be downloaded.
| [2015-04-27 19:16:38] |
These just open into text . http://www.sierrachart.com/index.php?page=doc/AdditionalFiles.php#Files I can right click but saves only as html ? Thanks |
| [2015-04-27 20:18:53] |
This is a browser configuration problem that we cannot help with. Let us know what files you want and we will send them to you by email. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-04-29 11:14:03] |
tried chrome I'm getting "invalid field code" in message log ? I'm probably going to give up at this point , and write out chart books long hand
