Date/Time: Sun, 22 Dec 2024 08:18:51 +0000
How to save trade window configuration
View Count: 1422
[2015-04-21 02:28:19] |
NumbersBars - Posts: 141 |
Sierra chart version 1241 I was referring to documentation of "Saving Trade Window Configuration" -To save the current trade window configuration, press the Menu (M) button on the Main or C tab of the Trade Window. Select Save Configuration on the menu. Enter a filename in the Filename box on the Save File window, and press Save. May I know where can I find "Save Configuration on the menu"? |
[2015-04-21 04:32:39] |
This is documented here: http://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#TradeWindowConfigurations There are screenshots near the end of the section which show the menu: http://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#DeletingConfiguration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
