Date/Time: Sun, 22 Dec 2024 08:35:42 +0000
How to draw (display) a hollow triangle on the chart
View Count: 1042
[2015-04-20 21:13:32] |
Rainer - Posts: 110 |
Using the Marker as a drawing Tool, we have Triangle up/down/L/R in full color, how can I also create a hollow Triangle with just an outline color? I have also tried using Type Text in conjunction with Windows Character Map by selecting a particular Font that has hollow triangles but when copy/paste such characters (and selecting the same Font in Text Properties) the result is a ? (is a question mark). Any other suggestions? A possible fix = make Marker Properties pop-up box to have color selector for Fill-Color & Outline-Color (instead of just Color) |
[2015-04-21 04:30:03] |
We will check on this.
[2015-04-23 22:46:29] |
Al SC Developer - Posts: 434 |
In the next version, there is a Hollow attribute for non-line based marker types.
[2015-04-24 08:25:57] |
Marek F - Posts: 244 |
Could you please to fix this issue, too? Bug in the displaying of the Triangle Best regards Marek |
