Date/Time: Tue, 04 Nov 2025 07:19:13 +0000
ACSIL QUESTION REGARDING ARRAY FUNCTIONS
View Count: 1133
|   [2015-04-20 21:04:42]     |
| enemyspy - Posts: 306 |
                Bare with me as I am learning and still suck at this stuff. Any Clarity on this would be appreciated as I am running out of subgraphs: The sc.Subgraph[].Arrays[][] I don't understand how use this properly via the reading material. Do I need to declare these arrays in the if(sc.SetDefaults)? Would the follwoing impractical example work to output the sum of the index of two background arrays to a subgraph? SCSubgraphRef x = sc.Subgraph[0]; if(sc.SetDefaults) { x.Name = "example"; return; } int a = 1; if( a = 1) { x.Arrays[0][sc.Index]=1; x.Arrays[1][sc.Index]=2; } if(x.Arrays[0][sc.Index]>0 && x.Arrays[1][sc.Index]>0) { x[sc.Index]= x.Arrays[0][sc.Index] + x.Arrays[1][sc.Index] } Date Time Of Last Edit: 2015-04-20 21:18:41
|   [2015-04-20 21:20:05]     |
                I modified this example in order to better ask if the calculation of the arrays works the same as if  using a subgraph.
|   [2015-04-21 07:22:48]     |
                A quick look shows that your code example looks fine. It is not necessary to give the sc.Subgraph[] a name in the sc.SetDefaults block if it will never be visible. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
