Date/Time: Fri, 22 Nov 2024 19:50:49 +0000
"INV"
View Count: 1602
[2013-06-01 15:44:31] |
Richard Reyes - Posts: 98 |
I am doing some back testing and after each session, I go the the "Trade Activity Log" and look at the "Trade Statistics" tab for applicable data. Just recently, I have been seeing "INV" in certain cells where there were numbers before. What is going on? many Thanks
[2013-06-03 16:28:18] |
Send us the TradeActivityLog.DAT file. This is located in the folder Sierra Chart is installed to. Send it to support AT Sierra Chart.com. Let us know the exact symbol you are back testing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
