Date/Time: Fri, 11 Sep 2026 18:56:40 +0000
Trade Management by Study stuck...
View Count: 1202
[2015-04-20 13:00:56]
UserNameTodd - Posts: 4
Hi guys,
Friday it was working, today (Monday) not....
TMS via EMA...in Sim mode for now...managed by stop...using Chart Trader with attached S/L offset = 10 ticks.
I'm using the TMS button allocated to Tool Bar 1.
2 observations:
1) When order is filled, the graphical trailing stop is always 1 tick from where it should be. The log is always showing a order has been modified New Price of xx.xx9999. These 9's are not in alignment with the current EMA value and where the current Stop should be trailing.
2) When order is filled, whether the TMS is enabled or disabled, the order is tracking via this TMS setting....I cannot not move Stop as it always pops back to the TMS - it seems to be stuck in TMS mode.
I tried removing and replacing TMS study, but still behaving the same.
Running version 1242
Incidentally the same scenario is working per set parameters very well on my partners machine.
Help!
Thanks,
Todd
[2015-04-20 13:26:50]
Update:
I've been trying different combinations to "enable/disable" TMS.
What seems to have righted the situation is this:
Disabled TMS via Studies Settings; entered trade; then enabled TMS via Studies: Settings.
Now, the TMS button on tool bar 1 is behaving correctly.
Any suggestions?
[2015-04-22 19:24:59]
1. The price is rounded to the nearest tick based on the tick size of the chart.
2. We need to do testing to see what the problem is with enabling and disabling the study.
