Date/Time: Sun, 22 Dec 2024 06:39:51 +0000
[User Discussion] - Help with ACSIL
View Count: 903
[2015-04-19 21:12:11]
eagle - Posts: 92
sc.AutoLoop = sc.Input[3].GetIndex();
With that statement below the sc.SetDefaults code block; whenever I change the Index of sc.Input[3], I have to press an Apply button twice for the change to take place (or some combination of an Apply button and an OK button). Just backing out with the OK buttons does not work.
With that statement inside the sc.SetDefaults block; it works when the study is first applied, but changing the Index does not change sc.AutoLoop.
How would I properly toggle sc.AutoLoop with an sc.Input?
[2015-04-19 21:33:30]
You are on your own with this. The behavior of this is going to be unpredictable and is unsupported.
This is something we will definitely not provide help with.
Date Time Of Last Edit: 2015-04-19 21:33:43
[2015-04-19 22:38:29]
eagle - Posts: 92
OK. Thanks.
It's actually sc.OnExternalDataImmediateStudyCall that I want to toggle. I was usig sc.AutoLoop just to test my code, but I've figured out how to test using sc.OnExternalDataImmediateStudyCall. So, I'm OK.
