Date/Time: Fri, 18 Sep 2026 13:06:02 +0000
Spreadsheet with two coppies of sierras
View Count: 1192
| [2015-04-18 00:04:04] |
| User786736 - Posts: 16 |
Hi, I know I can open multiple copies in one instance my question is can I have a spreadsheet for trading running on the source copy wile trads are been placed on the other connection? Ex. I have a futures data connection and I wish to use that data in order to place trads in a CFD connection. cheers |
| [2015-04-18 22:27:16] |
This is not supported.
| [2015-04-19 09:39:37] |
I would expect you to know bit more then me about sierra charts I just managed to do that..
| [2015-04-21 04:35:41] |
The way that the question was asked, it is not supported to give a trade signal from one instance that trades in another instance of Sierra Chart. But reading this again and thinking about it, if you were to open a chart that uses data from another instance of Sierra Chart, and change the Trade and Current Quote symbol for that chart, then it probably would work but it is not something we would normally explain how to do. We have to be careful not to make suggestions, which can be too complicated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
