Date/Time: Tue, 04 Nov 2025 17:55:31 +0000
VbP Value Area Horizontal Lines
View Count: 1094
| [2015-04-17 20:46:58] |
| User765038 - Posts: 22 |
SC, In the VbP study, if my volume bars are right-aligned on the chart, is it possible to draw horizontal lines (projecting leftward across the chart) at the value area high and low? Thanks and regards, Rod |
| [2015-04-20 09:28:02] |
We will make a note of this.
| [2015-08-18 19:17:33] |
Is there any update on this? Thanks and regards, Rod |
| [2015-08-18 20:07:34] |
Actually, this is already supported. We just had not reviewed this more closely previously. We had the impression that it was a feature request. You need to set the Extend Value Area Input with the study to End of Period. Refer to the documentation here for more information: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
