Date/Time: Fri, 22 Nov 2024 19:34:59 +0000
Global Setting>Symbol Setting>Rollover - who to set 5 days befor
View Count: 1601
[2013-06-01 06:28:11] |
pkhst958 - Posts: 57 |
How can I set the roll over to 5 days before expiration for the ES-#####-GLOBEX? >Number of calendar days before Friday count Number of calender days=5 Friday count=3 (ES-#####-GLOBEX expires third Fri of month) And choose Chart>Chart setting>Automatically rollover Would that b it? |
[2013-06-03 16:26:12] |
Yes. This is exactly correct.
