Date/Time: Thu, 24 Sep 2026 13:57:22 +0000
Is there any way to ping or check latency of the trading servers?
View Count: 2665
| [2015-04-17 14:28:37] |
| User950458 - Posts: 4 |
Hi, I am about to go Live with Rithmic in Sierra. I am in the UK and see there is a EUrope server, but just curious if I can check the latency on the servers incase there is a more optimal server for me? |
| [2015-04-17 17:35:16] |
Please contact Rithmic and see if they can help you with this.
| [2015-04-19 15:18:06] |
| Hendrixon - Posts: 130 |
In R|Trader in preferences you have a tab called Performance. (I'm writing from memory but look in the menu and you'll see what I'm talking about) Anyway you will find there a place to ping the Rithmic servers... Price, Orders and a third one. |
