Date/Time: Thu, 31 Oct 2024 10:13:01 +0000
period high and low
View Count: 1356
[2015-04-17 04:11:52] |
User15414 - Posts: 20 |
Can someone point me to a study that arrows a new high or low for x number of bars?
[2015-04-17 14:47:48] |
Sawtooth - Posts: 4103 |
There is no single study that will do this, but you can use a combination of studies. Try this: 1) Add the Highest High/Lowest Low Over N Bars study, check Hide Study. 2) Add the Color Bar Based On Alert Condition study -set the 'Output When Condition True' to 'Use Input Data' -set the 'Input Data' to the desired location of the arrow at new high. -set the Draw Style to an arrow -put this formula on the Alerts tab: =ID1.SG1<>ID1.SG1[-1] 3) Add another Color Bar Based On Alert Condition study -set the 'Output When Condition True' to 'Use Input Data' -set the 'Input Data' to the desired location of the arrow at new low. -set the Draw Style to an arrow -put this formula on the Alerts tab: =ID1.SG2<>ID1.SG2[-1] (where the Highest High/Lowest Low Over N Bars study is ID1) |
[2015-04-20 04:05:13] |
thanks Tom. That did arrow the 5 day high's/low's. I did not describe it right. It would be a bar that's high is higher than the previous four ands low is higher than the previous 4 bars. I will just have to look into how to program sierrachart. |
