Date/Time: Sun, 22 Dec 2024 02:56:31 +0000
Appearance of numbers bars on reversal bar chart
View Count: 978
[2015-04-16 17:26:22] |
User348701 - Posts: 23 |
Do you know why I get these color blocks on numbers bars on a TF reversal bar chart when I do not get the same color blocks on an ES chart with the same settings (except TF is a 8 tick reversal and ES is a 4 tick reversal)? Please see attached images. http://www.sierrachart.com/image.php?l=1429205059609.png http://www.sierrachart.com/image.php?l=1429205162396.png Thanks |
[2015-04-16 18:05:00] |
Not sure. Duplicate the chart and remove all studies from the chart other than the Numbers Bars study to see if that makes a difference. Here are instructions to duplicate a chart: http://www.sierrachart.com/index.php?page=doc/helpdetails20.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-16 18:48:17] |
I duplicate the exact same ES chart and change the symbol to TF and I still get the color blocks.http://www.sierrachart.com/image.php?l=1429209983973.png |
[2015-04-16 18:52:00] |
We specified to remove all of the studies from the chart other than the Numbers Bars study. Clearly there is some study drawing something. Also select Tools >> Erase All Nontext Drawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-16 19:42:33] |
Thank you. I removed them all and then one by one and found the culprit that was coming from another chart.
