Date/Time: Sun, 22 Dec 2024 03:09:39 +0000
question
View Count: 787
[2015-04-16 14:23:28] |
jimnovak - Posts: 42 |
i noticed that there is /graphics/buttons folder in sc directory. it contains loads of .bmp files. i assumed this is where the toolbar buttons look to pick up the appropriate look. but they dont. they seem to pick up their images from a .dll file(?). can the buttons look in that folder to associate a .bmp file for their appearance so one can change or replace them easily?
[2015-04-16 17:49:38] |
This capability is coming. And will be better supported. Probably next month. However, you should be able to change and add bitmap files there to alter the ToolBar buttons but you will have to restart Sierra Chart after. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-16 17:54:17] |
i did change a file for test. restarted sc but it didnt work. i have moved that folder altogether, restarted sc, but it didnt make a difference. toolbar buttons pickup their appearances from/through a .dll file.
