Date/Time: Sun, 22 Dec 2024 03:30:00 +0000
Rightclk->Add Symbol Alert not populating correctly
View Count: 787
[2015-04-16 14:21:44] |
Joe Hobart - Posts: 89 |
i dont use this feature everyday, but id say it broke sometime in the past month or so. It used to correctly populate the price i right clicked on, and i would just need to go in and add the 'crossing or equal'. It no longer populates a correct price. While you are in there, pretty please make the default 'crossing or equal' Thanks! |
addsymbol.jpg / V - Attached On 2015-04-16 14:21:38 UTC - Size: 213.18 KB - 296 views |
[2015-04-16 17:48:06] |
We are checking on this.
[2015-04-16 18:05:33] |
Al SC Developer - Posts: 434 |
This is addressed in the next version.
