Date/Time: Wed, 05 Feb 2025 11:54:00 +0000
candles tick body fill
View Count: 1860
[2013-05-31 22:35:44] |
User93731 - Posts: 83 |
At different trading platform I used currently, my candle stick acting like Renko boxes. When price is up (comparing to the last tick, NOT the OPEN PRICE of each bar), the body of stick is hollowed, when price is down, the body is filled. This happens no matter if it is a green (up) or red (down) bar. This is important feature for my trading. How could I do such thing on SC? Your help is greatly appreciated. Looking forward to your reply. Hiwhited |
[2013-05-31 22:47:45] |
M5amhan - Posts: 468 |
are you referring to the close of the previous bar when you say "last tick"?
Date Time Of Last Edit: 2013-05-31 22:48:07
[2013-05-31 22:59:48] |
Sawtooth - Posts: 4167 |
Go to Global Settings >> Graphic Settings >> CandleStick Up Fill and set the color to the same as your chart background.
[2013-06-01 00:07:14] |
Let us know if you need more help.
