Date/Time: Sat, 03 Oct 2026 02:59:26 +0000
Historical chart scale error
View Count: 1159
| [2015-04-16 12:11:14] |
| JingIt - Posts: 44 |
I'm using OEC data feed. When I create a new historical chart for daily for weekly settlement, the scale is incorrect, I try to reset or create another new chart but nothing change. I'm using 1247 version Date Time Of Last Edit: 2015-04-16 12:11:34
| [2015-04-16 17:38:48] |
We have tested this, and the data looks correct for us. Therefore, there probably is a data error in the historical data. You need to re-download the data for all contracts as explained here: http://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading Here is an image of what we see: http://www.sierrachart.com/image.php?l=1429205969708.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-16 17:39:37
