Date/Time: Sun, 22 Dec 2024 03:18:13 +0000
installation problem
View Count: 789
[2015-04-16 09:35:06] |
User14740 - Posts: 11 |
Dear collaborator in the support board. Since my old computer crashed I have to reinstall Sierra chart from the bottom. It took me already a lot of time, since my skills are very limited in finding the right criteria in this complicated platform. In the attached trade window to the chart the top part is still blanc. There is nothing to choose. I tried for many hours already, read a lot of the instructions, but it I cannot find it Here I want to find the number of contracts with common stop. (2 targets with common stop) How do I find this again? Thanks for your help. Peter van Soest |
[2015-04-17 03:51:32] |
We have attached the file that you need to this posting. You will see it at the bottom. Here are the instructions to use it: http://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#ConfigurationFileAnotherSource Let us know if you need more help. You should also see it if you just simply reinstall Sierra Chart. To do that select Help >>Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
Attachment Deleted. 2TargetsWithCommonStop.twconfig - Attached On 2015-04-17 03:50:09 UTC - Size: 6.18 KB - 341 views |
