Date/Time: Thu, 10 Sep 2026 02:33:02 +0000
Is it possible to remove this text/info from the top of my chart?
View Count: 5436
| [2015-04-15 16:49:16] |
| User950458 - Posts: 4 |
Hello, I just started using Sierra a few hours ago, I am coming from Ninjatrader and I am VERY impressed so far! I have been able to customize alot of things and spent a few hours going through different settings and have been checking everything out.. I would like to know if I can remove the text/info at the top of my chart? I've attached a screenshot so you can see what I am referring to, as my chart is very clean and I removed other text, so I was curious if I could remove this too. Cheers |
| [2015-04-15 17:14:03] |
Yes, this is possible. Select Chart >> Chart Settings >> Advanced Settings 2, within the Region Data Lines section, select Region 1, and set it to Hidden. Sierra Chart Support Date Time Of Last Edit: 2015-04-15 17:14:35
| [2015-04-15 18:24:08] |
Perfect, thank you.
| [2015-04-15 20:00:44] |
For more information, refer to the documentation here: http://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#RegionDataLine Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
