Date/Time: Sun, 22 Dec 2024 03:11:00 +0000
DOM study / horizontal bars
View Count: 1885
[2015-04-15 12:59:03]
User48021 - Posts: 2
This request is related to DOM cumulative bid/ask volume columns
As I'm also interested in stacking/pulling feature of the DOM and have some swdev skills I decided to write a study for that as I read in another post, that it should be possible w/ ACSIL.
I checked all data needed for calucaltion and everthing looks good from that perspective but I ran into some issue when bringing the data to user. After some recherche I was not able to find a documentation or sample code, so I decided to ask:
1.) is it possible to draw horizontal bars as it used in the volume by price study. I expected to achive this when using
sc.GraphDrawType = GDT_VOLUME_BY_PRICE;
but I was not able to actually draw anyhing when using that GraphDrawType. Can you provide an example how to do that
2.) I was able to write out the stacking orders as text value to a study using multiple different sc.Subgraph[] - finally we want to have those data displayed in the DOM, so I used the price/study overlay study to make my study visible in the dom.
is there a way to directly make my study usable in the DOM window like the volume by price study does? Can you provide an example how to write a DOM study?
thank you for your help & kind regards,
Markus
[2015-04-15 18:20:14]
1. This Graph Draw Type cannot be used from ACSIL.
You would need to draw wide lines with square edges using the ACSIL drawing tools:
https://www.sierrachart.com/index.php?page=doc/doc_ACSILDrawingTools.html
2. Just add the study as a custom study to the trade DOM. This is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#AddingStudiesTradeDOM
When you press to Chart >> Studies >> Add Custom Study button, any of the studies listed can be added.
[2015-04-15 21:13:42]
drawing bars using lines works good for me also as dom study.
thank you & regards,
Markus
