Date/Time: Mon, 20 Jan 2025 11:25:39 +0000
NYSE Advance/Decline
View Count: 3077
[2015-04-15 12:47:05]
User25116 - Posts: 27
I am following a professional trader and I noticed that I have been using the wrong symbol for "NYSE advance/decline" and I really don't see anything else that has the same wording or description for that. I explained my situation to him and he said it might be the feed or I am using the wrong symbol.
I noticed his has a 0 line that is why I think I am using the wrong symbol and I need help trying to find it. He is using Tradestation and his symbol is $ADD for NYSE Advance/Decline what does that symbol translate to for Sierra.
Date Time Of Last Edit: 2015-04-15 12:59:02
imageAdvancedecline.jpg / V - Attached On 2015-04-15 12:58:21 UTC - Size: 690.68 KB - 702 views
[2015-04-15 18:02:13]
All of the available market statistics symbols are documented here:
Sierra Chart Market Statistics
Most likely you need:
NISS-NYSE
[2018-06-17 08:03:50]
User164231 - Posts: 278
While on the subject of Market Statistics, is there a way to control the amount of days to load? Despite inputting 150 days it still loads from 2015 Sep 21.
[2018-06-17 17:11:55]
Alberto Gauer - Posts: 121
Advance/Decline line is the NISS-NYSE chart.
The ADR chart is the Advance/Decline ratio.
[2018-06-18 07:10:49]
To understand this, refer to:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DateRangeInFile
