Date/Time: Sat, 21 Dec 2024 17:03:21 +0000
sc.scGetTradeListEntry questions
View Count: 853
[2015-04-15 02:49:58] |
onnb - Posts: 662 |
In simulation mode, is there a way to filter between simulated and replay/backtest? The list of trades includes all the trades for the symbol, yes? (Including trades of this symbol from other charts) |
[2015-04-15 05:18:34] |
The Trades you can access are based upon the currently set Simulation Fills Source setting: https://www.sierrachart.com/index.php?page=doc/doc_TradeMenu.html#SimulationFillsSource And it does include trades for the same symbol entered from other charts . Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
