Date/Time: Fri, 22 Nov 2024 19:43:57 +0000
Linking multiple charts
View Count: 2216
[2013-05-31 21:05:05] |
guyl - Posts: 58 |
I would like to be able to link several charts of different time frames together. I have a 2 min, a 5 min, and a 15 min chart. I would like to be able to SCROLL the 15 min and have the 5 min and the 2 min move with the scrolling 15 min in the proper time frame. Meaning if it is currently 4:00pm and I scroll back the 15 min chart to 11:00am I would like the 2 and the 5 to follow so I don't have to manually move those charts to 11:00am. Can I do this with Sierra charts? Thanks |
[2013-05-31 23:07:31] |
M5amhan - Posts: 468 |
http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#LinkNumber you are looking for "link scroll position" |
[2013-06-02 00:47:37] |
The answer given in post #2 is correct. Let us know if you need more help.
