Date/Time: Sun, 22 Dec 2024 03:32:53 +0000
Sierra Chart CME data with Transact account
View Count: 906
[2015-04-14 20:51:10] |
superdoug3 - Posts: 40 |
Pricing question 1. I am currently with Transact and I have Sierra Chart (level 3)through Transact 2. I am only interested in ES tick data 3. I currently have Transact data which CME exchange charges me $6/month for my ES data 4. From Sierra Chart pricing page I think that I would pay $35/month for Sierra Chart ES data feed and an additional $6/month to CME exchange for the 2nd data feed, is this correct ? 5. Can I add this data feed through my Transact Sierra Chart or do I need to purchase a level 3 Sierra Chart from you ? 6. I guess I would be billed $35/month from Sierra Chart and additional $12/month from Transact for the 2 CME data feeds I am using as well as the Sierra Chart software fee if I do not meet their usage minimum. 7. I have a DSL line at 6 Mbps, will this be more than sufficient for Sierra Chart data feed. If not, can I limit my data feed to ES Tick data as I do not need 100 symbols. I currently have my chart set up to ES data only. i.e. no $TICK, $TRIN etc. |
[2015-04-15 19:51:47] |
this is a question about pricing for Sierra Chart data feed. I understand I post to support board to get a reply or do I post/phone somewhere else ? I have viewed the pricing page but I don't understand
Date Time Of Last Edit: 2015-04-15 19:57:58
[2015-04-15 19:59:10] |
This is the right place and we will have a response soon.
[2015-04-16 04:10:55] |
3. The exchange fee from Sierra Chart for the CME Group is 3.25 USD per month. 4. The cost for the Sierra Chart Exchange Data Feed is is 35 USD a month for the first connection and for the CME Group it is 3.25 USD per month. 5. You will definitely need a direct account and pay for Sierra Chart directly. Here are instructions: http://www.sierrachart.com/index.php?page=doc/doc_DirectAccount.html 6. We are not sure about fees from TransAct, but we have explained above the costs for the Sierra Chart services that you require. 7. This is more than sufficient. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
