Date/Time: Sat, 19 Sep 2026 12:41:47 +0000
axis Y on volume/delta study
View Count: 1932
[2015-04-14 20:08:23]
User30743 - Posts: 399
hi there.
i use volume and cum. delta quite a lot and have them put in my chart like this http://prntscr.com/6trwus the problem is that i dont know how to make the axis Y show the volume level. i have cumulative delta first and volume second in my studies - http://prntscr.com/6trynj but but if i swith the studies in the setting and put the volume FIRT and delta SECOND http://prntscr.com/6trzc0 - the delta disapears from my chart http://prntscr.com/6ts08h
and i dont know how to make it!! could you please help
[2015-04-15 04:47:45]
We will only accept screen/chart images posted using the method documented here:
Or here:
You need to set each of these studies to use an Independent Scale Range as documented here:
Chart Studies: Overlaying Studies in the Same Chart Region on a Chart
That documentation also explains to enable the Use Left Side Scale.
Date Time Of Last Edit: 2015-04-15 04:49:57
