Date/Time: Sun, 22 Dec 2024 03:01:32 +0000
Forex to Futures
View Count: 869
[2015-04-14 18:50:57] |
User631237 - Posts: 2 |
Presently in trial mode with a Forex (FXCM) account that will be morphing into the 40/month option when trial is over.........am adding a futures account (AMP)......how do I handle that? Thank you, Frank Wetherbee |
[2015-04-16 17:56:18] |
You need to have a direct Sierra Chart account which you already do, the one you used to post to this Support Board message with and this account can be used with FXCM and AMP. You can install two copies of Sierra Chart on your system. One to use with each. Here are instructions: http://www.sierrachart.com/index.php?page=doc/MultipleServices.html#StepByStep Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
