Date/Time: Sat, 21 Dec 2024 17:00:44 +0000
1247 Pre Release Problems
View Count: 1331
[2015-04-14 14:49:37] |
Zosimus - Posts: 345 |
After upgrading from 1241 to 1247 Pre Release I am suddenly getting Run-Time Check Failure #2 - Stack around the variable '__' was corrupted. for variables from a custom study that worked smoothly on 1241 and also getting Circular reference errors on the SC message log that never appeared on 1241. After downgrading back to 1241 all error messages stop. Date Time Of Last Edit: 2015-04-14 14:52:03
[2015-04-14 17:33:27] |
We are checking on what might be causing this.
[2015-04-14 18:04:35] |
Our first look into what we suspected could be the problem did not identify it as the problem. So we are still thinking about this.
[2015-04-14 18:05:51] |
No worries, I am not in a rush to upgrade.
[2015-04-14 18:21:23] |
If it is not a problem could you install 1247 into another folder and recompile your custom study using that version and let us know if there is still a problem. This will help us better understand the source of the problem.
[2015-04-14 18:22:03] |
sure
[2015-04-14 18:32:46] |
Ok, Upgraded to 1247 pre release. Built the study again (with Visual C++). When trying to build on 1247 getting a message "error C2039: 'GetChartDrawing' : is not a member of 's_sc'" Were any changes made to the sc.GetChartDrawing() function ? |
[2015-04-14 18:35:13] |
This has a new name. It is: sc.GetUserDrawnChartDrawing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-04-14 18:36:16] |
yes, Just found it on the What's new section. I will change and see if this solves the problem. |
[2015-04-14 18:40:21] |
Problem solved. I will make sure to keep up to date with the Changes log. Thanks for you patience and kind help. |
[2015-04-15 04:15:36] |
The renaming of that function cannot be the cause of the problem that you had. So something else is causing the original problem and we are not sure what it is. We will continue to think about this and see if there are other reports of a similar problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
