Date/Time: Sat, 04 Jul 2026 08:38:44 +0000
Trading platforms
View Count: 1500
| [2015-04-14 13:32:43] |
| ertrader - Posts: 697 |
What are the best SC Supported trading platforms that FULLY support both Server Managed OCO AND Server Managed Bracket Orders? I am very familiar with IB (which does fully support them) but often there are issues. I have already looked thru all the trading services listed by SC but I am looking for recommendations. Thank you |
| [2015-04-14 17:12:57] |
Server side bracket orders are supported with CTS T4, Interactive Brokers and OEC. It was previously supported with CQG, but we had some occasional problems we would hear about and disabled support for it on CQG. Among these, we generally would recommend CTS T4. The problem with OEC and bracket orders is that until the parent order fills, it is not possible to modify the Target or Stop. Otherwise, we generally almost never hear about problems with server-side OCO or bracket orders when using OEC. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-22 00:49:37
| [2015-04-21 22:29:58] |
This really helps...thank you!
| [2015-07-17 06:30:34] |
| User929392 - Posts: 11 |
Hi - Same question as etrader in post #1. Only now it is three months later, and given the rapid development of this functionality, I wonder if your response is still the same as in post #2? Thanks in advance.
| [2015-07-22 00:51:11] |
The response is still the same as post #2: Trading platforms | Post: 56939 Since this time, there has been one change with bracket orders with Interactive Brokers and that there is no attempt to modify under any condition the Target or Stop Attached orders upon a parent fill which can sometimes result in the order quantities of those Attached Orders to be less than the actual quantity due to a simultaneous increase in quantity by Interactive Brokers managing the quantities of the bracket orders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-07-22 00:51:26
| [2015-07-22 13:31:55] |
Can you please clarify "there is no attempt to modify under any condition the Target or Stop Attached orders upon a parent fill"? Does this mean that for IB managed OCO orders, the Target and Stop QUANTITY is not modifiable or the PRICE value? Or, is there something else? I did not fully understand the update explanation in post #5 Thank you Date Time Of Last Edit: 2015-07-22 13:33:04
| [2015-07-22 18:28:57] |
Does this mean that for IB managed OCO orders, the Target and Stop QUANTITY is not modifiable or the PRICE value? Refer to the documentation here about this: https://www.sierrachart.com/index.php?page=doc/doc_GlobalTradeSettings.html#AdjustAttachedOrders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
