Date/Time: Sat, 21 Dec 2024 17:15:10 +0000
delta
View Count: 833
[2015-04-14 09:47:33] |
stephensmart - Posts: 51 |
Hi, the ask/bid volume difference bars study, i presume is calculated on delta, is there a way to calculate it on up/down tick volume cumulative delta or is there a different study for that? Thanks |
[2015-04-14 18:25:46] |
No. There is not and there are definitely no plans to add support for this because it only leads to accuracy problems which the user may not even be aware of. We do not understand what cumulative delta has to do with this. There are the Cumulative Delta Bars studies: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s296 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-14 18:26:43
