Date/Time: Fri, 25 Sep 2026 16:38:23 +0000
SFE for Sierra Charts data
View Count: 1166
[2015-04-14 02:33:24]
olambeth - Posts: 30
Hi there,
I'm looking to use SC with OEC as my broker. I don't want to use OEC's data for the Sydney Futures Exchange however I am considering Esignal. Three questions I have for you:
- Is the SFE connected to SC intraday data?
- Is Esignal's data supported by SC?
- Could you recommend other data sources other than IB that would provide SFE intraday data that is compatible with SC?
Many thanks for your kind help!
Oliver
Date Time Of Last Edit: 2015-04-14 02:34:38
[2015-04-14 03:15:10]
Does OEC support the Sydney futures exchange? We thought this was only supported by Interactive Brokers and CQG.
We recommend using CQG. Only Interactive Brokers and CQG would be the supported sources for Sydney futures exchange trading and data.
[2015-04-14 03:20:01]
They are integrating the SFE as we speak. Shouldn't be too long until they have it.
I'll check out CQG.
I believe DTN IQFeed supports ASX24 too.
Oliver
[2015-04-14 03:34:30]
OK.
[2015-04-14 03:46:00]
Does SC support Esignal?
[2015-04-14 03:58:20]
No. Refer to:
Our Experience with E-Signal
