Date/Time: Sat, 21 Dec 2024 17:25:31 +0000
[User Discussion] - tt/net AMP no account balance
View Count: 914
[2015-04-13 18:06:14] |
User965571 - Posts: 5 |
Orders appear correctly. Balance does not show
[2015-04-14 06:14:17] |
User13668 - Posts: 294 |
You should check/search the documentation before posting as the answer is easy to find - see below. That is probably why SC support have not responded as your question is distracting them from more important work. http://www.sierrachart.com/index.php?page=doc/AMPTTNet.php#AccountBalance |
