Date/Time: Thu, 15 Oct 2026 03:14:49 +0000
Frozen charts/prices
View Count: 1424
[2015-04-13 14:12:00]
User53601 - Posts: 107
I am connected via Interactive Brokers and use IQfeed data.
As of today I have problem with charts.
The price is not moving. If I reconnect again, SC reload all data till the time of reload, but the price of all charts is "frozen" and not loading new data.
Many thanks for your help
[2015-04-13 16:10:51]
Go to the instance/ copy of Sierra Chart connected to IQ Feed and open a chart for one of the symbols that is not updating and see if the chart updates there.
If not, refer to help topic 3:
Http://www.sierrachart.com/index.php?page=doc/helpdetails3.html
If it does update there, also refer to help topic 3 for reasons why the chart may not be updating in the instance of Sierra Chart connected to IB.
It sounds like you are not receiving the real-time data from IQ Feed. Help topic 3.4 will confirm this:
http://www.sierrachart.com/index.php?page=doc/helpdetails3.html#h3.4
Date Time Of Last Edit: 2015-04-13 16:13:18
[2015-04-13 20:20:30]
I did not find the solution.
I went to the instance/ copy of Sierra Chart connected to IQ Feed and opened a chart.
Chart do not updates in realtime, however it updates once, in the case when I switch off/on data connection.
I communicated with IQfeed support:
" We’re not experiencing any data issues on this side."
I excersised the followings in the instance/copy of Sierra Chart connected to IQ Feed:
1.
After these two steps:
File >> Disconnect
File >> Connect to Data Feed.
the data were downloaded, however only once. Afterwards no updating takes place.
2.
No values are displayed in: Window >> Current Quote Window
3.
Chart >> Chart Settings on the menu.
I checked the following and there is no checkmark by Advanced Settings >> Disable Data File Updating
4. This box is set to blank:
Main Settings >> Use Date Range >> To
5.
File / Connect to datafeed - is disabled.
Should it help, I can put here Message log.
Date Time Of Last Edit: 2015-04-13 20:21:22
[2015-04-13 20:57:55]
Both of the following are a clear indication the problem is on the IQ Feed side. Contact them again and insist there is something wrong with the transmission of the real-time data.
2.
Possibly restarting the IQ Feed software may be enough. Refer to step 10 here:
DTN IQ Feed Data Service: Setup Instructions
Date Time Of Last Edit: 2015-04-13 20:59:04
