Date/Time: Sat, 21 Dec 2024 17:09:08 +0000
How can I see the total market depth
View Count: 827
[2015-04-13 13:21:43] |
User965571 - Posts: 5 |
at the DOM
[2015-04-14 03:45:06] |
Refer to the documentation here to add the Bid and Ask Size columns: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizeChartDOMColumns You also need to possibly increase: Global Settings >> Data/Trade Service Settings >> Requested Market Depth Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-04-14 03:46:08
