Date/Time: Sat, 21 Dec 2024 16:52:47 +0000
Trading system in "Replay Chart Mode" and "Simulated Trading"
View Count: 845
[2015-04-13 11:21:20]
FerroTrader - Posts: 70
can I code a trading system that I can both test in "Replay Chart Mode" and I can use in real time trading ?
My aim is to validate my trading system in replay chart mode first, and use it in simulated mode during real time trading (my data feede is IQFeed DTN).
Does SierraChart permit to do this ?!
Thank you a lot for your support,
Andrew
[2015-04-13 16:49:22]
Yes here is the information for back testing:
http://www.sierrachart.com/index.php?page=doc/doc_Backtesting.php
When you are back testing, you can do this with a replay and replay at any speed that you want if the replay is done manually.
[2015-04-13 18:18:46]
Thank you.
How can I add to a chart a volume profile composite ?
Thank you
Andrew
[2015-04-14 03:50:13]
Refer to the documentation for the Volume by Price study:
http://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html
