Date/Time: Sat, 21 Dec 2024 13:08:58 +0000
Sell limit
View Count: 869
[2015-04-13 09:56:39] |
Michaela Nepovimova - Posts: 8 |
Good morning, I have got the problem with sell limit order in live trading (my broker is OEC). Please, let me know how to set when I want to put sell order and my sell order is above the actual price, it is not possible and there appers the note, that the order must be below the actual price and the order is rejected. So there must be something wrong in setting. How should I set it to enable put the sell order above the actual price and it will stay valid? Thanks in advance. Have a nice day. Míša |
[2015-04-13 16:23:17] |
It sounds like you are actually submitting a Stop order instead of a Limit order. If you are using the Trade/Chart DOM to enter the orders, refer to step 6 here: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#ChartDOM You may have an incorrect setting and actually instead be entering a Stop order. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
