Date/Time: Sun, 22 Dec 2024 08:04:44 +0000
CME exchange
View Count: 2511
[2015-04-13 00:21:29]
User95521 - Posts: 53
I just bought CME exchange and renewed the data feed.
But in the symbol list, it looks just like the BATS exchange.
(Now I have both CME amd BATS)
Could you please help me to check it?
Thank you!
Best Regards!
imageCME.png / V - Attached On 2015-04-13 00:21:21 UTC - Size: 76.6 KB - 405 views
[2015-04-13 00:42:50]
The lists that you see do include the CME futures.
For example, if you want to look at the ES S&P 500 mini futures, you will find this listed under File >> Find Symbol >> Futures - Indices.
If you do not see a particular symbol listed, let us know.
Date Time Of Last Edit: 2015-04-13 00:43:09
[2015-04-13 01:06:50]
Many thanks for your replying.
I still have a BATS exchange.
After purchae CME exchange, The symbol list did not change.
BATS do include some symbol from CME.
Please see the screenshot.
When I download EUROPOUND, not a signal bar could be shown.
In BATS exchange, I could only download EURUSD, AUDUSD, NZDUSD intraday data, so I deceided to buy CME exchange.
One of my friend have CQG chart system with CME data feed, it include all major pairs and cross pairs, which is different from what I am seeing.
Thank you!
Best Regards!
image1.png / V - Attached On 2015-04-13 01:05:57 UTC - Size: 92.25 KB - 380 views
image2.png / V - Attached On 2015-04-13 01:06:06 UTC - Size: 81.31 KB - 394 views
image3.png / V - Attached On 2015-04-13 01:06:33 UTC - Size: 101.74 KB - 374 views
[2015-04-13 07:01:26]
The symbols EURUSD, AUDUSD, NZDUSD are spot Forex symbols. The CME provides Forex futures data as well as other markets.
Did you require Forex futures or spot Forex data?
We have updated the symbol settings for the RP?## symbols. You will need to update the Symbol Settings following the instructions here:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps
Let us know if you need help with any other symbols. If the CME exchange is not what you want, you need to let us know in a matter of hours if you want it canceled so we can try to get it canceled and refunded for you, if possible.
Date Time Of Last Edit: 2015-04-13 07:02:22
[2015-04-13 14:17:38]
I need both FX spot and futures data.
I apologize for the bad habbit in expressing FX futures symbol, which leading to misunderstanding.
But in after I add CME  exchange pachage, no symbol list added.
Only 16 sysbols is from CME, which is the same with BATS.
Among which, only EuroFX,Australian Dollar,Newzealand Dollar could be download about one month's data.
Other symbol could not download a single bar.
This is much different from my friend's CME exchange which used on CQG chart system.
Could you please help me to solve the issue?
Thank you!
Best Regards!
[2015-04-13 16:51:22]
What activating the CME exchange the list will not change. All of the available symbols are already listed. If you do not see a particular symbol listed, let us know which ones so we can add them.
Let us know what symbols you are not getting any data for.
To get more historical data for other symbols, refer to the Continuous Futures Contract Chart documentation here:
http://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html
For spot Forex data, install another copy of Sierra Chart on your system and set it to use the Sierra Chart Real-time and Historical Forex Data Feed:
http://www.sierrachart.com/index.php?page=doc/SCRealTimeFOREX.php
[2015-04-13 17:16:58]
OK,no problem.
Many thanks for your kindly help!
I'll mail the list in an excel file to support@sierrachart.com in 1-2 days.
Including the needed symbol and some could not be downloaded symbol.
Thank you!
Best Regards!
[2015-04-13 20:21:57]
Please do not send them by email. Only post them here. You can put them in a file and make it private if you want.
You can find the symbols here:
http://www.cmegroup.com/trading/fx/#majors
Only list the symbols that Sierra Chart currently does not have listed for the SC Exchange Data service.
And also be aware that some symbols may not be actively traded and there may not be much data for them if any.
Date Time Of Last Edit: 2015-04-13 20:22:30
[2015-04-14 12:01:01]
I placed the file here, please check it.
Thank you!
Best Regards!
Private File
Private File
[2015-04-15 06:11:44]
Thank you for this. We will go through this list. But it would help if you could update the Excel file with the actual symbols you see from the CME website here:
This symbol is shown in the "Code" column.
[2015-04-15 07:16:46]
OK, No problem.
I'll update them tonight.
Many thanks for your help!
Have a great day!
[2015-04-16 07:54:17]
I have updated the list.
Very sorry for the delaying...
Please check it.
Thank you!
Best Regards!
Private File
[2015-04-19 17:46:14]
If possible, could you please firstly send me the finished part of the file?
I do need them now.
I apologize for the inconvenience to you.
Thank you!
Best Regards!
[2015-04-20 03:09:33]
We are mostly done with this. We will finish up with the final details in a few hours and post here when done.
In the case when you want to get charts that go further back in time, use the Continuous Futures Contract feature:
We made certain that is properly supported for all the symbols.
Some of the symbols the server was not tracking so we have to add some historical data for those, but as of this moment historical data is being maintained for those symbols.
Date Time Of Last Edit: 2015-04-20 03:10:20
[2015-04-20 06:48:01]
OK, Thank you very very much for your help!
I'll wait for the data.
Have a great day!
[2015-04-20 22:21:46]
Follow the instructions here to update the Symbol Settings to get the latest updates:
http://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps
For some of the less active contracts which have been added, we still need to load in the historical data but there really is not much, but that will be done in the next few hours.
All of the symbols you requested and were not previously available you will see listed in File >> Find Symbol. Some of the symbols do not match exactly the CME symbols, but you can tell from the description what they are.
Date Time Of Last Edit: 2015-04-20 22:22:03
[2015-04-21 03:48:58]
Many thanks for your great help!
I have just updated from server and try to download the new data.
If still have questions, I'll look for your help again.
Thank you again for your help!
Best Regards!
Date Time Of Last Edit: 2015-04-21 03:55:58
[2015-04-21 04:29:27]
For these particular symbols:
"PSF", "PJY", "SJY"
Data for them is only available on one of the servers. So if you do not initially get the data select, Edit >>Delete All Data and Download.
Data will be available for them on all the servers in a couple of days.
These are not actively traded markets though.
